Asset UPnP 4.1 not running
  • kjartan
    • Nov 2010
    Just updated Asset UPnP from 4 beta to 4.1. on my WHS 2011 server. The Update went OK and Asset configuration confirm that the version now is 4.1, but as status is say "not running". I have tried the restart button but nothing happens. Anybody know what to do?
    • 46189
    Re: Asset UPnP 4.1 not running
    Uninstall Asset, restart the computer and reinstall.
    • kjartan
      • Nov 2010
      Thanks Spoon for your advice. I uninstalled the Asset software + the add-in and reinstalled and that made the magic, now it is running:-). But the Asset Configuration software has disappeared and I have problems making contact with Chorus DSHD on my Ipad to the Asset UPnP server. Kinsky and Chorus DS works fine. Another thing - In the Asset UPnP folder there is only a Help-file, can't find the software anywhere else than as an add-in in WHS Home Server 2011. Is that supposed be so?
      Kjartan
      • dbfan
        • Jan 2011
        • 937
        The configuration is a page on the whs dashboard, you have this?
        • kjartan
          • Nov 2010
          Yes, I have, but before I had piece of software in the start menu called "Asset Configuration" with options "lokal" or "Service" etc. This I do not have anymore. Any idea why problems with Chorus on the Ipad.
          Kjartan
          • dbfan
            • Jan 2011
            • 937
            You do not get those with the whs install.
            If other control points pick up asset from the iPad, then the issue is with chorus
