WASAPI + UPnP(DLNA): low sound quality
  • rumblebox
    • Nov 2012
    I'm using Asset UPnP V4.1 to grab the audio out of my laptop and to stream it to my sound system and it works! However, the sound quality is bad, since there is almost no bass. In contrast, if I play a mp3 file via the same UPnP server the quality is perfect. Changing the audio stream format of WASAPI from 'as is' to 'mp3' or 'wav' had no effect on the low bass issue. I think the source of this problem is the WASAPI. Is it possible to change it's settings? Can anyone else confirm this behavior?
    Thanks in advance!
    • 46231
    Re: WASAPI + UPnP(DLNA): low sound quality
    The sound is captured as is, there are no settings.
    • Rabye
      • Jan 2013
      @rumblebox, yes I confirm this behaviour.
      @spoon, how do you explain the bad sound quality ?
      If I capture the sound with another software, like wifi2hifi for example, I have no such problem.
      Can you explain how the sound is captured ? What can we do to have a better quality ?
        • 46231
        You should set the capture options to match the source:
        right click on Windows Speaker >> recording devices >> properties >> advanced >> default capture
        • newbiew
          • Nov 2014
          Hi Spoon I am a new user and a novice experiencing the same poor sound quality noted in this old thread when streaming PC Sound Capture [WASAPI] via DLNA to a Cambridge StreamMagic 6. I am running Windows 7 Home Premium and can't track down the above settings. Can you please point me in the right direction? Apologies if this is something very basic. I also have WASAPI set to stream "as is" in Asset which I presume is correct.
          Thanks for your help
            • 46231
            I do not think it is possible to stream to the Cambridge with WASAPI, because they constantly close the stream, then reopen when need more data (if the poor quality is breaks in the sound every few seconds).
            • newbiew
              • Nov 2014
              There are no breaks in the sound - it is just very thin and lacking bass and breadth of sound frequencies. I'm keen to try your suggested Windows Speaker settings above if I can track them down. Any other thoughts on the Windows or sound card side that may influence it?
                • 46231
                You have set WASAPI to stream as lossless wav on the advanced settings page?
                • newbiew
                  • Nov 2014
                  I've tried that and no sound comes through with a message "End of Queue". I can only get it to come through as MP3 (when set to "as is" or MP3). I'm streaming via ethernet. Might try direct connection via usb to see if that makes any difference (although that means having my computer close to my renderer.
