Scanning library after changing Mediadatabase fields is bad / needs weeks!!! HELP!
  • MajikDS
    • Feb 2010
    • 16
    I changed the mediadatabasefields.text to add "Label" as a tag.
    Recommended is after changing to make a "refresh all".
    Now my library scanned 120 songs of my 40000 after 12 hour, that's not normal!!!
    Any idea how to solve?
    Thanks in advance.
    • 46027
    Re: Scanning library after changing Mediadatabase fields is bad / needs weeks!!! HEL
    Perhaps you change the file wrong, close asset, delete the mediadatabasefields.txt
    Then restart asset and try a full rescan without the label, to see the time taken.
    • MajikDS
      • Feb 2010
      • 16
      Ok, deleted the whole system and installed new.
      Now it detects fast.
      Before I'll try again my changes.
      Here is what I want:
      I made a tag called "Label" . I use MP3tags for that things. I want to use it the same way as "Genre" What should I change?
      Pleas help.
      • MajikDS
        • Feb 2010
        • 16
        Nobody can help me?
          • 46027
          See:
          http://forum.dbpoweramp.com/showthre...t=asset+custom
