Two instances of asset running
  • Galaxian
    • Jan 2012
    • 9
    I've got two instances of asset-upnp.exe running under windows task manager (Windows 8).
    Under ccleaner, windows startup includes:
    Asset upnp umedialibrary.lnk
    Asset upnp.lnk
    Under start-up under windows task manager there are two instances of asset-upnp (low and high startup impact)
    Is this correct?
    Regards,
    • 46231
    Re: Two instances of asset running
    It is correct, once asset starts another, then if the other asset crashes, the first asset could start a new one, without having to reboot the machine (if was running as a service).
