Problem with asset UPnP with and Cambridge Audio NP30
  • pantau
    • Oct 2012
    Hi
    I have following configuration.
    Windows7 64bit and Asset UPnP4.1 installed.
    As renderer I use an NP30 from Cambridge Audio.
    When I'm playing back a flac file (CD Rip) I get dropouts after about 40s.
    Playing a mp3 or ALAC file works without problems.
    As I find out, the 40s is about the buffer size of the NP30.
    For testing I installed another UPnP Server (Minim) on the same computer and there is no problem with Flac playback.
    Is there a setup problem in Asset or what can I try?
    Regards
    Beat
    • 46231
    Re: Problem with asset UPnP with and Cambridge Audio NP30
    Wired or Wireless connection? most wireless connections are not able to supply lossless files over a period of time.
    • pantau
      • Oct 2012
      Wired connection. As I wrote, with the Minim Server running on same machine and using the same connection, there is no problem.
      I was also running two Linn DS Players on the sam network plug, and there was also no problem in playing this flac file.
      Regards
      Beat Graf
        • 46231
        Asset is set to not transcode the file? because this player (if I remember) constantly opens and closes the stream, which is a no-no for transcoding.
        • pantau
          • Oct 2012
          That's it. Asset was set to transcode Flac to WAV. Know it works.
          OT: Is there a MAC Version of Dbpoweramp in queue?
            • 46231
            Not currently
            • gorkitek
              • Oct 2012
              Where is there a menu in Asset enabling changes in transcoding?
              • gorkitek
                • Oct 2012
                Ooops sorry, found it!
                G
