Settings Override (Control Point Specific)
  • Kurt1232
    • Jan 2012
    • 10
    I would like to play HIRES Flacs also on my Sonos System (old problem ;-)). Now I can play files on my Sonos System directly from the Asset Server and it works well for LOWRES. At the Control Point Specific adjustment page within Asset I see under Known Control Points: Linux UPnP/1.0 Sonos/19.3-56060 (MDCR_iMac11,1).
    I defined this Rule Based Profile at the left side of the panel:
    =Sonos
    [StreamMax16Bit]
    [StreamMax48KHz]
    Also after a restart of Asset the Sonos controller still displays a sample rate which is to high to be played.
    Thanks a lot for any help!
    • 46231
    Re: Settings Override (Control Point Specific)
    You would have to enable streaming for the formats in question. These options only come into effect when Asset changes the stream.
    • Kurt1232
      • Jan 2012
      • 10
      Thanks for your answer! What format should I choose for Flacs? 'as is single' would be ok and what does it mean? Do I have any losses in quality on my High End Linn equipment due to enabling this kind of streaming?
      Thanks, Otto
        • 46231
        You would have to enable Wave streaming, for example.
        • adca1
          • Oct 2011
          • 20
          I have a similar issue with my Reciva radio (Sangean WFR-20) which is not HiRes capaple. My Music files are stored as flac (+ a very small number as mp3 or WAV). I can stream my ripped CDs without any problem. In order to listen to Hires files as well I made the following entry at the Control Point Specific adjustment page:
          "=Reciva
          [ForceToWAVE]
          [StreamMax16Bit]
          [StreamMax48KHz]"
          I have also tried:
          "=Reciva
          [ForceToMP3]"
          I then restarted both AssetUpnP and the radio. Unfortunately it does not work: Whenever I try to stream a HiRes file I get some strange noise from my radio (beep beep or so).
          NB: Under "Known Control Points"Within Asset, there is an entry "Reciva [...]"
          Thanks for any idea how to correctly transcode the HiRes for my radio.
          adca
          Post scriptum: In the general settings, all formats (except .m4a) are set to stream "as is"
            • 46231
            Are you using Asset R4.1?
            • adca1
              • Oct 2011
              • 20
              Yes, an AssetNAS running R4.1.
                • 46231
                Try enabling debug mode, restart asset, serve one file to the player then look at the debug file, it will show what Asset did with that file.
                • adca1
                  • Oct 2011
                  • 20
                  Thank you. Tried and verified. It was probably a typo (Wave/kHz/mp3 instead of WAVE/KHz/MP3). There are still frequent dropouts esp with 192/24 files and the replay is uneven when I use transcode to Wave/48/16; when forced to transcode to mp3 it works. When I use the Twonky App for iPod as the control point, streaming (WAVE/48/16) is ok. Probably 44.1KHz is the max a WFR-20 can correctly handle when it is the control point and the client. Can I define a lower maximum frequency ?
                  adca
                    • 46231
                    It is not possible to set 44KHz there.
