Various issues using Asset uPNP
  • gkime
    • Oct 2012
    Hello, I have had asset up & working for a few days now, accessing via the Stream Magic 6 player from CA, controlled by the Stream Magic iPad app.
    I am having the following issues and would appreciate any assistance you may be able to give.
    1. I am finding that the jukebox track selection playlist is not accurate - I will choose 1 song but the player plays something different: E.g. I chose Canadian brass song and got the eagles instead
    2. Alphanumeric search does not work - it never returns search results
    3. The random play doesn't choose a very random selection of tracks
    • 46189
    Re: Various issues using Asset uPNP
    1. Is possibly a bug in the Stream Magic, as this feature has been around and used for about 1.5 years and has never been brought up before.
    2. Our search quite specific as to what fields it can support.
    3. The random feature uses the rating of the files to weight the results.
    • gkime
      • Oct 2012
      WRT *1 - I have logged the same issue with CA, I hope they do not suggest it is an Asset issue - I just want it to work - could it be a misalignment of the album art with the song that is causing this?
      2) When I enter the title of a song into alphanumeric search, sometimes is returns quickly, but, sometimes I never get a response, any suggestions?
      3) More info: When allowing the entire song to play, the random is working just fine, however the "next" button to skip a song does not work - is that a SM or an Asset issue?
        • 46189
        3) Asset only does random at the selection level, your player if pressing next does not work, that is an issue with the player (perhaps related to 1)
        2) Sorry we do not have any.
        • gkime
          • Oct 2012
          Should there be to Asset upnp processes running on my PC, I wonder if the trialware did not unintstall correctly and if that would be contributing to my instability?
            • 46189
            Only if Asset is installed, if you uninstall Asset then it is all gone from the system.
