Asset and Crossover and iTunes - help
  • tony clarke
    • Mar 2012
    Hi - my first post.
    Tried out the Asset UPnP (DLNA) in conjunction with Crossover on my Mac mini hardwired over the ethernet to hi-fi. Controlled via iPad. I had been using this for my iTunes with playback - but the artwork gets muddled. Took up on a suggestion to try crossover and asset. Got it working ok during the free trial, purchased both products. Followed the instructions - Hasn't worked since!
    Can anyone please help with a comprehensive installation guide?
    The Macbook also has parallels installed on it but I don't have iTunes on there. I noticed that it maybe installing Asset there? It didn't appear to be doing so during the trial. No idea what is happening?
    Any ideas - help!
    Tony
    • 46189
    Re: Asset and Crossover and iTunes - help
    Asset would work better under Parallels, you do not need iTunes with Asset.
    • tony clarke
      • Mar 2012
      Hi Spoon,
      Thanks for that - as all my downloads are on iTunes is there some documentation to refer to as to how to transfer the library to a NAS or keep it on the MAC. I am a bit of a novice - what's the best option? I have a NAS
      Tony
        • 46189
        If you have the option, keep the files on the MAC, as local files are easier to access (no passwords, etc).
