Cannot add or remove folders In Audio Library in Advanced Settings
  • producer2k
    • Feb 2012
    I'm sure that there's an easy answer, but I can't figure it out. I cannot add or remove folders In the Audio Library Box in Advanced Settings. I click on Add folder and it just sits there. Nothing happens. I have my music library on an external drive and cannot add it to the library. I've even tried redirection and registry searches but no good. Any suggestions should would be appreciated!
    producer2k:cry:
  • dbfan
    • Jan 2011
    • 937
    Re: Cannot add or remove folders In Audio Library in Advanced Settings
    When you click add a system 'Browse for Folder' should display, if this does not display then it suggests you might have a location which is stalling it, such as a network location.
    • producer2k
      • Feb 2012
      Thanks a million for your response. I cannot change the folders from the Configuration GUI, but I found the medialibrary.txt and changed the redirection. Works for me now. Bit of a pain.
