Problem with Asset Upnp after registration
  • hockey
    • May 2011
    After receiving my Naim Uniti a few weeks ago I downloaded the free version of Asset UPNP to listen to spotify. Since yesterday my Naim when selecting Asset Upnp - PC Sound Card Capture (WASAPI) gives the following message: Reguires Asset Premium Registration, please visit www.dnpoweramp.com.
    So I purchased this through the website, registered and downloaded the file on my laptop. Unfortunately with no success as it still gives the same message. Now I can't listen to Spotify and this is quite frustrating as I did purchase the premium upgrade via this website.
    Who can help me? Thanks in advance.
    • 46231
    Re: Problem with Asset Upnp after registration
    The current version of Asset R3 will only register if installed to the default path:
    C:\Program Files\Illustrate\dBpoweramp
    • hockey
      • May 2011
      Saved it into this folder and restarted the computer...still no joy.
      Any other suggestions?
      • hockey
        • May 2011
        Also when I have saved it and get the screen where you can choose the local account and can restart asset it still shows the functionality as "free" and not premium registered.
          • 46231
          Are you running the 64 bit version of Windows?
          • hockey
            • May 2011
            Yes. Windows 7 - 64 bit
              • 46231
              The installation path should be:
              C:\Program Files (x86)\Illustrate\dBpoweramp
              For 64 bit windows.
              • hockey
                • May 2011
                Thanks! It works!
