Something odd going on with Asset with Oppo -95
  • ny941932
    • Apr 2011
    I just started using Asset with Oppo-95 and have noticed some odd behavior.
    When I choose to listen to a particular Album, once it drills down to the track list, there is nothing there. Thus, the only way to listen to music is to select Title and then scroll through all the tracks.
    It doesn't happen all time though: sometimes when I click on the album the tracks are there and sometimes they are not.
    I have no connectivity issues, as mentioned before, all tracks play just fine when found through the Title list.
    I'm using a wireless connection.
    Also, since I'm streaming FLAC files, should I select L24? and in the audio format streaming leave FLAC at "as is" or change to "LPCM".
    thanks in advance.
    • 46216
    Re: Something odd going on with Asset with Oppo -95
    For the oppo L16 is automatically selected. It sounds like a bug with the oppo, other players can browse without issue.
    • petacat
      • Sep 2010
      • 11
      It is hard to track down problems related to oppo 93/95 at the moment because DLNA is "experimental" according to them.
      I have been having trouble with streaming as well. Sometimes it takes 20 seconds to start the next track and asset control does not even see the oppo.
