help with sound card capture xbox
  • rpuri
    • Jan 2011
    just purchased full version of Asset UPnP v3
    added PC Sound Card Capture [WASAPI] as Child of Root
    set WASAPI to LPCM
    But I can not see it listed anywhere on the Xbox menu.
    What am I doing wrong?
    Jamcast virtual soundcard worked flawlessly on Xbox and showed up under playlists. how can i setup Asset to play sound card capture on Xbox?
    • 46231
    Re: help with sound card capture xbox
    The xbox does not list the browse tree asset gives out, so it cannot play [waspi]
    • pap247
      • Aug 2011
      Is there any solution to this problem? This is the reason I purchased this software!
      Please help,
      Ed
        • 46231
        Not unless the Xbox change their software to allow Asset to show its browse tree on the XBox.
        • pap247
          • Aug 2011
          Can you not employ the same technology as jamcast to negate the problem? Thanks for your time
          • kc8iqw
            • Jan 2013
            Is there any plan to use whatever Jamcast uses to allow direct sound capture to the XBox? I would much rather use this software as Jamcast is overkill for me.
            • dbfan
              • Jan 2011
              • 937
              There are no plans sorry
