Help on Beta3
  • paddle
    • Jan 2011
    • 8
    Help on Beta3
    I have been using beta 2, which was installed by my hi-fi dealer. I have just installed beta 3 (trial version), which is not picking up any music: status library contains 0 tracks 0 music.
    It has been picked up by my Ipod touch, which I use as a remote for my Linn Majik DS. Can you please help: i am not technically minded and dare I say 60 years of age.
  • ServerBaboon
    • Sep 2009
    • 52
    Re: Help on Beta3
    What is asset installed on?
    Is it a pc or a ripnas or another Windows home server based server.
    I'm guessing that if is being picked up but not seeing any tracks then maybe Asset is looking in the wrong place?
    If you have bought this recently either the Linn or server device then you should be able to get some advice from the dealer especially if they are Linn.
    • paddle
      • Jan 2011
      • 8
      Re: Help on Beta3
      It's installed on a PC - Vista. I was using Asset 2 beta in the same way and Twonky from the pc and also Stora separately.
        • 46231
        Re: Help on Beta3
        Where is the music stored, on the same PC or a NAS?
        • paddle
          • Jan 2011
          • 8
          Re: Help on Beta3
          On the same PC
          When ServerBaboon mentioned that it was probably looking in the wrong place I went through the installation process again. When following that I noticed that it hadn't picked up my music folder, so I added it - perhaps I was supposed to do that in the first instance.
          It now states that the Library contains 14,000 tracks, 2098 albums> However, although it is shown as a device on my Ipod Touch (using PugPlayer) all the A-Zs are there but no files/music. I'm obviously doing something wrong.
          Thanks for your concern and support.
            • 46231
            Re: Help on Beta3
            Restart the computer, then do a full rescan (refresh all). Let it finish before browsing with your plugplayer.
            • paddle
              • Jan 2011
              • 8
              Re: Help on Beta3
              Thanks - all now working. I can now register/purchase with confidence.
