Problems with searching on own tags / just Label and publisher ?!
  • MajikDS
    • Feb 2010
    • 16
    I tried to add Label and Publisher to Browse tree and added both as
    label,0,NVARCHAR(150)
    publisher,0,NVARCHAR(150)
    in the MediaDatabaseFieldsv3.txt file.
    BUT no items are shown if I search in Label or Publisher....?!
    I tagged all with mp3tag and found out that "publisher" in mp3tag is thge same as "label" in Asset, cause if I make a right click on an a flac file an use edit ID-tag from dbpoweramp it showed me under label the publisher info.
    What am I missing that searching is not working?
    I made a refresh all and a Restart too.
    Please help
  • MajikDS
    • Feb 2010
    • 16
    Re: Problems with searching on own tags / just Label and publisher ?!
    here you see the listings:
    • MajikDS
      • Feb 2010
      • 16
      It would be nice if spoon or someone else could help me.
      Here is the shoot for a file of itself with the tag label:
        • 46231
        Browse to %progfiles%\illustrate\dbpoweramp
        and run the uMediaLibrary-dumpdb.exe program, this will show if the program has read those ID tags.
        • MajikDS
          • Feb 2010
          • 16
          And then???
          It would be easier for most people to get more notes...
          After running I got a huge *.txt file with a lot of text. What should I do with that?
            • 46231
            Save it as .xls and load into excel, everything will be formatted correctly then.
            • MajikDS
              • Feb 2010
              • 16
              And then again...?
              What am I looking for?
              Do you want the xls-file (23,9MB) ?
              A little more help for those who don't work in his job with programs like yours would be helpful, e.g. customer service.
              Just told me how I can get the browse tree function for me and everything is ok.
              Thanks in advance
                • 46231
                I do not know why it is not working, so you need to look into it. Once you load it in to Excel there will be a column 'Label' and you can see if Asset has been able to read any tags from the files.
                • MajikDS
                  • Feb 2010
                  • 16
                  Ok, I understand.
                  There is no column with label nor publisher.
                  Are my mediadatabase.....txt and the browse tree right?
                    • 46231
                    You must have a different mediadatabasefieldsv3.txt file which asset is using, is asset running as a service?
                    • MajikDS
                      • Feb 2010
                      • 16
                      What do you mean as a service, I'm using WHS with the Asset msi.
                      • MajikDS
                        • Feb 2010
                        • 16
                        I found 2 files on my pc. One under administrator (which I changed), another one under default user, completely different (see below).
                        I'll post them.
                        Should I delete all under default user?
                        • MajikDS
                          • Feb 2010
                          • 16
                          Or should I delete all under administrator?
                          The newer ones (date access) should be on the default user account
                            • 46231
                            Do not delete any, add your extra lines to the one under Default User, then rescan.
                            • MajikDS
                              • Feb 2010
                              • 16
                              I copied my changed one to default user and made a rescan...no changes
                              BTW,
                              asset is running as a service
