Album Artist sort problem
    Found another sort issue. In the following example shown in Asset Control, all files are flac and use the album artist sort tag, so Paul McCartney albums have McCartney, Paul in the album artist sort tag.
    Paul McCartney is listed after Harry Nilsson (Nilsson, Harry) when it should appear before Christine McVie (McVie, Christine), next to The Fireman (McCartney, Paul).
    • 46231
    Re: Album Artist sort problem
    It looks like it is sorting on 'P'
      Yes I agree. It should be sorting on 'M'.
      ...20 minutes later:
      Just removed the 10cc folder from Asset and sort is now correct. Looks like a bug.
        • 46231
        10cc should not effect it, try re-adding it please.
          Re-added the 10cc folder, then Asset UPnP config Refresh All and sort order is incorrect as in the post no. 1 image.
          ...5 mins later:
          Just done a complete database rebuild. Sort order is definitely incorrect.
