Radiotime streaming problems/Asset R2.1
  • bytey
    • Jan 2010
    I use the registered version R2.1 of Asset on a Windows Vista machine. When I am connected (100Mbit LAN) to my PS3 the playback of mp3 files is working fine. Listening to radio stations, listed by radiotime, is also working on the PC.
    When I try to select a internet radio stream on the PS3, the playback starts but gets corrupted after a few seconds of listening. It sounds like some sequences are fast-forwarded or something similar.
    Bytey
    • 46189
    Re: Radiotime streaming problems/Asset R2.1
    You have set the streaming option to LPCM?
    • bytey
      • Jan 2010
      Sorry for the late response.
      Yes, I set it to LPCM. When I set it to Wave or mp3 the playback does not start.
      Is there any opinion to modify buffer settings or something?
        • 46189
        The ps3 cannot support wave, mp3 should be supported, LPCM should definately be supported.
        • bytey
          • Jan 2010
          I found out how to fix the problem. The output rate was set to 44,1/88,2/176,4kHz instead of 48kHz.
          I don't know why that caused the problem, because the AV receiver should be able to handle this setting.
          Thanks and regards,
          bytey
