24 bit FLAC streaming problem
  • timan
    • Nov 2009
    I am getting temporary drop-outs when using Asset to stream 88.2Khz 24bit flac files from a Tranquil Windows Home Server, eg every 20s or so. I'm using Assest v2 running as service, streaming to a Linn DS. I have killed indexing on the WHS, so CPU load is low all the time. Using process explorer, it looks like I/O reads are temporarily stopping for Asset.
    I don't have this problem with lower bit-rate Flac files. The Flac files themselves play ok (& stream OK if use an Asset UpNp server on a different pc - but I don't want to have leave a PC on to serve the files which are stored on the WHS anyway ...).
    Any ideas?
    Thx
    • 46231
    Re: 24 bit FLAC streaming problem
    100 Mb network could handle 10's of such streams, so your network is not a limiter (unless you are using wireless or home plug).
    It points to an issue on tranquil box.
    • timan
      • Nov 2009
      The I/O reads includes disk I/O (network and disk I/O are not separated in the diagonostics; the likely problem is inability to read from the disk) : something bad is happening between the h/w, WHS s/w and the Asset UPnP s/w.
