res element in container XML
  • henkelis
    • Sep 2009
    • 10
    I'm writing a UPnP control point (primarily aimed at Sonos but will serve any UPnP server and render to any UPnP renderer). It happily browses Asset, but it can't directly play a container - this is when served either directly or via Sonos. I know that there's a problem with Sonos playing a container when its browsing Asset itself, but I ought to be able to play one outside of Sonos serving (I can play a container from Twonky via the Sonos renderer for example). It appears that Asset doesn't provide a res element with the URI of the container - is that by design?
    Mark.
    • 46080
    Re: res element in container XML
    Yes, we could not get it to work with Sonos (through its controller).
    • henkelis
      • Sep 2009
      • 10
      I guess you're not intending to support multi-track play for any UPnP control point/renderer then?
        • 46080
        Yes in Asset v3
        • henkelis
          • Sep 2009
          • 10
          Great, thanks.
          • logon68
            • Dec 2010
            i agreed with henkelis
