Beta still does NOTwork with Yamaha receivers...
  • davidfi01
    • Mar 2009
    Spoon -
    The WHS beta still does not work with Yamaha recievers.
    The server is found by the yamaha and it displays:
    (N/A) Asset UPnP:Server
    It also displays the native WHS media connect server string as:
    Server:1:Windows Media Connect
    When you select Asset, nothing is browsed.
    When you select media connect you see the drill down menus
    Is there any other data I can help you with?
    D
    • 46231
    Re: Beta still does NOTwork with Yamaha receivers...
    Do you know what the (N/A) means?
    • davidfi01
      • Mar 2009
      The Yamaha shows the Media ID string as:
      Computer name (Server): # (unknown ref number): Media Server Name (Windows Media Connect)
      I guess that the (N/A) indicates that your server is not returning a string that is formated as the Yamaha DLNA wants to see it ...
      D
      • gcoupe
        • Mar 2009
        • 8
        My bet is that N/A means Not Authorized... What I used to see on my Denon before Spoon put a fix into Asset that solved the problem...
        • txgriz
          • Mar 2009
          Any update on this? On my 3800, I don't see the Asset showing up as available devices at all. Im surprised to see there may be a difference between the 3800 and 3900.
          • txgriz
            • Mar 2009
            Anyone know if Release 2 works with Yamaha or should I not bother with this anymore?
