dBpowerAMP Music Converter R9 Beta 4
    • 46085
    This one has a few minor bug fixes and two new features for Audio CD Input, namely a CD spin up option before ripping, and an option to specify an Username and Password on a proxy server. Download:
    1.4MB
    The next beta release should get offline freedb ability.
    All changes:
    Audio CD Input - Send a (WM_USER + 101) message to Audio CD Input it starts ripping
    Audio CD Input - Options Menu gets a new 'Character Replacement' option window - now possible to set the characters that are replaced and with what (certain characters such as * / cannot be used in filenames)
    Audio CD Input - Added Track right click menu pictures
    Audio CD Input - Power Pack Option - Compilation button gets a menu for multidisc albums - so can set a track offset number like 10..11..12
    Audio CD Input - Option to output to folder is also on CD Input page, this has fixed a bug where installed on a fresh machine and never ripped with options, it would try to output to 'Same as Original', ie an Audio CD.
    Audio CD Input - Option on 'Rip as One' to set From and To Frames - for finer control
    Audio CD Input - File Creation page - Remembers the last 10 entries for quick selection
    Audio CD Input - Added an option to spin up drive before ripping, a minimum spin up time can also be set
    Audio CD Input - so can work with proxy that needs a password
    CDA Input Codec - Supplies more info for popup info tip, now more compatible with dAP
    Codecs - Added 'Professional Frequency Conversion' option to dMCs Configuration page, the following codecs are compatible with this option - Wave, mp3 (Lame), Ogg Vorbis, WMA v8
    Wave Compression Codec - Enhanced handling of Stereo >> Mono attenuation
    dMC Config - for Mp3 - Added option to create V1 and v2 id tag files
    mp3 Lame - uses Latest Lame 3.92
    mp3 - added .mpa files to the Mp3 decoder
    bug fix - when ripping from a CD, it makes sure that delete source files is not checked.
    bug fix - If using 'Auto Rip' - now will not show the options page - will just convert
    bug fix - If using 'Auto Rip' and 'No freedb Messages' and the Disc is not found in freedb the disc is now auto ripped
    bug fix - Audio CD Input would incorrectly switch of NT Built-in CD Communication method if ASPI was not installed
    bug fix - Well sort of, reworded the warning about 'DSP Effects in use' when using Aux Input, to mention 'Volume Normalize'
    bug fix - Audio CD Input - if there is a background image, it is now drawn correctly
    bug fix - Auto Rip now works again
  • ARcane
    LAME 3.93
    I found a new LAME Alpha (3.93), I post the Link later coz I had harddrive crash. Stay tuned ! ^^
    cYa ARcane
    • ARcane
      LAME 3.93 Link
      So I found it now :D
      Homepage of LAME Mirrors & Alpha Versions :
      --> http://mitiok.ma.cx/
      Or direct download (v3.93):
      --> http://mitiok.free.fr/lame-20020505_4.zip
      See Version histroy here:
      --> http://lame.sourceforge.net/history.html
      Good Luck when compiling new Beta 5 ^^
      ARcane
      • totalXSive
        • 222
        3.93 is still in its early stage at the moment - currently there has only been one improvement over 3.92. Proper releases come about every 3 months or so.
        [size=2][b]Neil T :)[/b]
        [url=http://www.neilturner.me.uk/]My weblog[/url] [url=http://www.audiopod.co.uk/]AudioPod - MP3 news[/url] :cool: [/size]
