Integrating Arrange codec to conversions.
  • Stenu
    • May 2003
    • 11
    How about integrating the functionality of the arrange codec to every conversion, in place or in addition to the simple rename feature.
    The problem is, I rip my CD:s in ape format to a directory d:\lossless, as artist\album\xx-track.ape, and then I want to convert these to mp3 in d:\mp3, keeping the same artist\album\ structure. Using the dMC file selector options "Keep path when convert", I get d:\mp3\lossless\artist\album\xx-track.mp3, which is not quite what I want.
    Stenu
    • 46045
    Use Windows to map 'd:\lossless' to drive L:\ then it will work as you want it.
    • Stenu
      • May 2003
      • 11
      Ok, that works, although it's not a very elegant way to do it ;-)
      Stenu
