Acronova Nimbie
  • usernaim
    • May 2009
    Acronova Nimbie
    Acronova looks to be replacing the Dupliq with the Nimbie, which is available in NB11 and NB12 guises.
    The MSRP is dropped to $599 and the price at Guitar Center is the same $469 as the Dupliq. The unit looks physically nicer and simpler, is smaller, enclosed, takes 100 discs, and can be loaded continuously, working in FIFO fashion.
    What's more it comes with QQripper software that integrates with iTunes and WMP.
    Of course I'd like to use dbpa for its AccurateRip capability.
    Are there drivers or plans for them? Any chance it will use the same driver as the Dupliq?
    And does anyone have any experience with the unit, which was announced in June.
    • 46115
    Re: Acronova Nimbie
    I do not think it does use the same driver.
    Currently there are no plans to add support.
    • usernaim
      • May 2009
      Re: Acronova Nimbie
      This unit looks like the best buy in the autoloader space. As it's new, the resale value will be higher than for older units too. And I don't imagine the Dupliq will be continued forever.
      Furthermore, since the Nimbie supports ripping on iTunes and WMP, it seems to me you are losing a potential market for dbpa reference if you don't support it. Up to this point, you offered software with no competition but now you have a competitor--one that is inferior, but free and works with the most common software.
      How can I convince you to support it? If you did decide to do so, how long would it take?
      • bhoar
        • Sep 2006
        • 1173
        Re: Acronova Nimbie
        Just an FYI: the acronova Nimbie is OEM'd from datatronics (who sells them as the Junibox). Similar to how the DupliQ was OEM'd from datatronics (who sells them as the minicubis).
        The minicubis-based platforms were selling for several years before spoon supported them. I suspect if and when there is a large enough target market out there, spoon might reconsider...but his development schedule looks pretty packed these days.
        Out of curiosity, what is the competitor you mention?
        -brendan
        • usernaim
          • May 2009
          Re: Acronova Nimbie
          The competitor I refer to is the giveaway software that comes with the Nimbie, called qqripper. It supports iTunes and Windows Media Player, and both the new and old Acronova units as well as the Datatronics units.
          Product info here:
          Software info here:
          • stoneditch
            • Aug 2010
            • 8
            Re: Acronova Nimbie
            Hello,
            I had a Nimbie deliverred to me yesterday with a lightscribe drive. I used it over night to rip lossless to Apple format using iTunes and QQripper. It worked well although I would rather use the DB Batch ripping app. I have just started to look at the options that allows command/control strings to be sent to the unit. Has any one had any luck in doing this? Maybe Spoon will reply and say that thay are developing some controls for it. I certainly hope so.
            • stoneditch
              • Aug 2010
              • 8
              Re: Acronova Nimbie
              Ok, I'm not a coder but I do have 20yrs in the IT industry. How do I go about getting Batch Ripper to control my Nimbie (v. silly name btw). Assuming that spoon is tied up doing other things to dbpa or other things that he may have on the go. It came with some drivers written by Broadex but I don't see how to get these to work with Batch Ripper.
                • 46115
                Re: Acronova Nimbie
                You would have to implement your own Load.exe, unload.exe and reject.exe
                At the simplest level these are called with --drive="X" where X is the letter of the CD drive.
                • stoneditch
                  • Aug 2010
                  • 8
                  Re: Acronova Nimbie
                  Spoon, ok thanks for this but I need you to be a bit more verbose. Looking at the folders where the other drivers reside, dupliq etc, there are txt files with configs and dll's.
                    • 46115
                    Re: Acronova Nimbie
                    Dlls are specific to the loader in question, they are not always needed. The Txt file is there to supply default command line options (as seen by Batch Ripper Configuration, see the Manual Load - Auto Eject for an example).
                    • audiodude
                      • Oct 2010
                      Re: Acronova Nimbie
                      Where can I find drivers for the Dupliq for Vista x64?
                        • 46115
                        Re: Acronova Nimbie
                        Answered on your other thread.
                        • caymanred
                          • Jan 2011
                          Re: Acronova Nimbie
                          Contact the manufacturer. They provide update drive that may support Vista x64.
                          • hifivalue
                            • Mar 2011
                            Re: Acronova Nimbie
                            It works great. dbpa should write the code to run it. It would be a great combo.
