sample offset
  • Qwaz
    • Jan 2005
    • 23
    sample offset
    if you have a CD drive with an ofsett of +800 how much of a track would i miss/add on in seconds
    (i know its a small amount just wondered how much exactly it was
  • neilthecellist
    • Dec 2004
    • 1288
    Re: sample offset
    whoa....Right now I feel like a n00b. Usually, I help a lot in the Support Section of the dBpowerAMP forums, but this is not something I can help with, so I'll just say this: What is an offset on a CD Drive?
      Re: sample offset
      We'll let Spoon answer this via a post in the AccurateRip forum: http://www.audiosense.org/forum/show...ghlight=offset
      To summerize: CDs have 44100 samples per second. Your offset is the amount the CD has to read into the data of the CD to get to the "start" of the audio. On some CD drives, this may mean losing some data, but even 800 samples isn't too much as compared to 44,100 each second.
