Enhanced AACPlus (AACPlus v2) Codec
  • bsiegel
    • Feb 2005
    • 17
    #61
    Re: Enhanced AACPlus (AACPlus v2) Codec
    Originally posted by mnbruin
    Is there any way to make the 3gp output file hinted for streaming servers? Thanks in advance?
    Not with the reference encoder, at least. You may want to read the reference materials to see if the codec supports this.
    Check 26.401-26.406.
    --bsiegel
    • bsiegel
      • Feb 2005
      • 17
      #62
      Originally posted by dimzon
      @bsiegel
      please, provide fresh patch (higher bitrate support) too
      I've updated and recompiled from the latest code drop (rev 710). I would have updated the first post in this thread, but apparently I can't edit any posts older than 60 minutes :(
      New encoder plugin:
      New patch file:
      New source:
      --bsiegel
        #63
        I edited your post to point to the new version.
        • boycie
          • Feb 2007
          would an MPEG 4 AAC plus V2 encoder be possible in the near future. Like the one on WINAMP, on the its called high bitrate encoder aacplus. Just wondering thx :D
            #65
            dMC r12 and the new Nero mp4 encoder supports this.
            • lucky
              Banned
              • Nov 2004
              • 80
              #66
              I upgraded to dmc r12 and the aacplus enhanced codec doesn't work now :blush: i think everything is installed correctly
              • icampana
                • Apr 2007
                The Enhanced AAC Plus encoder works fine, but I cannot add tags to the resulting file, does anyone know where I can find info about how to add it, I've been reverse engineering some m4a files generated by the nokia encoder, those are enhanced AAC and have tags included, but I'm not sure if it is a standard.
                  #68
                  The current m4a tagging standard is the standard used by iTunes, I believe, though Nero is trying to use a competing tagging format. I believe I remember hearing something about Nokia phones wanting m4a files with ID3v2 tags, but I may be mistaken.
                  • davidlandy
                    • Apr 2007
                    Can anyone help? How do you install this codec? I've put it where it looks right, under C:\Program Files\Illustrate\dBpoweramp\encoder but dbPowerAmp doesn't pick it up...
                    Thanks in advance,
                    David
                    • davidlandy
                      • Apr 2007
                      ... the conversion starts, but I get an error saying:
                      "Error: Unable to load encoder 'Enhanced AACPlus (CLI)'. [dbCoreConverter::dbCoreConverter]"
                      Hope this helps.
                      David
                        • 44017
                        #71
                        The encoder is not for R12, only the older r11.5
                        • hyeewang
                          • Aug 2007
                          hi, Besigel
                          I download 26410-710.zip and tested it,thanking the great software 26410-710.zip. Buy why it only support sampling rate 32k,44.1k 48khz? others?
                          • hyeewang
                            • Aug 2007
                            hi, Bsiegel. I am Sorry for spelling mistake ur name ! But I did not found the menu "edit" & do not know how to edit the post to correct it .
                            I downloaded the aacplus source code from 3gpp & test it. Float code is fine. But the fixed code (after 26411-630.zip) is terrible. Bad nosie spring with normal audio signal all along. Noise--hundreds of horses are running. Surprised , the fixed code before 630 is fine. Also , I found the problem happen in encoder code ,not decoder code. Maybe Coding technology release it before testing. ? The difference between 26411-630 & 26411-620? Anyone is kind to tell it?
                            • AustinBraun
                              • Aug 2007
                              hello to all How do I install this Codec?
                              • hyeewang
                                • Aug 2007
                                Conformance testing---- what does it mean? what does it do?
