Quality and accuracy
  • Qwaz
    • Jan 2005
    • 23
    if i rip a song from an unscratched perfectly formed cd i have just bought and i rip it as a wav file, is it 100% accurate or not
    and if not always can i check the accuracy?
  • adaywayne
    • Nov 2004
    • 383
    Re: Quality and accuracy
    Most of the time CD rips give a near-perfect result. DMC has an "Accurate Rip" feature in which you can compare your ripped CD with what results other got . But it has to be the same CD, so don't expect too many comparisons for the CD
    "Miff Mole And His Molers" from 1927.
    Arnie
      To check for accuracy of ripping you'll have to first check your drive for accuracy in general with one or several key cd's (look into the Accurate rip procedures).
        • 43928
        • neilthecellist
          • Dec 2004
          • 1288
          does accuraterip just make a good rip? is there the factor that maybe the CD drive hasn't been cleaned recently or anything like that??
          • Qwaz
            • Jan 2005
            • 23
            surely when you install a program or load up a file from a cd the CD drive does this 100% accuratly otherwise it wouldent work
            why isnt this the case with music ?
              Because data CDs have robust error correction, which is why you can only fit 700MB of data onto a CD but 80 minutes of audio.
              • adaywayne
                • Nov 2004
                • 383
                My apologies for misleading anyone. I should have said that the CD ripping feature of DMC "is compatible with AccurateRip" not that AR was part of it.
                Arnie
                • adaywayne
                  • Nov 2004
                  • 383
                  But isn't it also the case that music in CDA format (16-bit, 44100Hz,stereo) requires only about 8.5MB per minute (not the 10MB usually stated), plus then you have the lead-in and lead-out data to add which does bring the total to almost 700MB for an 80-minute CD?
                    • 43928
                    Audio CDs lack the error correction, if an error is encountered the CD Player will 'fill in the blanks', most of the time you cannot hear it, but on a badly scratched CD you will hear popping.
                    • neilthecellist
                      • Dec 2004
                      • 1288
                      would cleaning the CD drive with one of the those fat CDs from Staples help the CD drive to read data better?
                      • Qwaz
                        • Jan 2005
                        • 23
                        yeah, i once copied a blur album off a friend but the back of it had all bobbled up and on some of the tracks it would pop and leave blank bits
                        • adaywayne
                          • Nov 2004
                          • 383
                          Mea culpa. Forget the above. I really messed up in my arithmetic!!!
                          Arnie
