Asset UPnP is not showing up.
  • Jgeffen
    • Feb 2024
    • 14
    I have installed the latest Asset Synology app again on my new Synology NAS with Relatek CPU, including the latest DSM version, and it seems to work fine after scanning my music, but I don't see it in my UPnP app on my Mac and other devices. I installed the Mac version too and that is working fine on all my devices.
    What can be the cause of this 'NAS failure'? In the past it was working fine too.
    • 43928
    Re: Asset UPnP is not showing up.
    Try restarting everything, including nas and router.
    • Jgeffen
      • Feb 2024
      • 14
      Thanks, but that did not work, unfortunately...
        • 43928
        Are you able to access the settings page for Asset running on the NAS?
        • simbun
          • Apr 2021
          • 460
          I've never had a Synology, but would firewall rules get configured with the Asset install (assuming there is an active firewall)?
          • Jgeffen
            • Feb 2024
            • 14
            Yes, thanks, and everything on that page is working fine.
            My whole library is scanned correctly and exactly the same as with the Asset Mac UPnP scan.
            The latter is working fine on all my devices, as I wrote before.
            This page is also telling me: 'Version: R2023-06-06 [Linux-ARM64]; Functionality: Premium Registered; Updates for life'.
            But I do have the 'Realtek RTD1619B SoC' CPU. Can that be the cause, although it seems to work fine?
            • Jgeffen
              • Feb 2024
              • 14
              Hi, thanks for helping, but I did try this but not solution.
                • 43928
                Your CPU is arm v8 so should be fine.
                • Jgeffen
                  • Feb 2024
                  • 14
                  Okay, clear, thanks!
                    Super Moderator
                    • 1365
                    If you can access settings, Asset program is running but somehow being blocked from being found by other machines on your network.
                    Please try this on your Mac: https://www.dbpoweramp.com/beta/AssetFinder.dmg
                    It's a simple app I made for listing & configuring Asset instances on your network. Does it find your Synology Asset?
                    • Jgeffen
                      • Feb 2024
                      • 14
                      Thanks Peter, it doesn't find my Synology Asset...
                      What I can think of is that after migrating my old NAS to the new one, by moving the WD red drives to the new NAS, perhaps some old files left behind making this situation.
                      Gr. Jos.
                        Super Moderator
                        • 1365
                        Please open Synology control panel, Connectivity / Security / Firewall.
                        Is the firewall feature enabled or not?
                        If yes, please allow incoming connections on port 26125, which is being used by Asset media sharing service.
                        • Jgeffen
                          • Feb 2024
                          • 14
                          That did not help too. Even not when I disable the firewall.
                            Super Moderator
                            • 1365
                            In your web browser, please try loading:
                            http://[ip]:26125/DeviceDescription.xml
                            Replace [ip] with IP address of your NAS
                            Does it show anything (should show raw device description of your Asset) or does it entirely fail loading?
                            • Jgeffen
                              • Feb 2024
                              • 14
                              Hi Peter, I got this:
                              This XML file does not appear to have any style information associated with it. The document tree is shown below.
                              <root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:dlna="urn:schemas-dlna-org:device-1-0">
                              <specVersion>
                              <major>1</major>
                              <minor>0</minor>
                              </specVersion>
                              <device>
                              <deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType>
                              <friendlyName>Asset UPnP: HomeServer</friendlyName>
                              <manufacturer>Illustrate Ltd</manufacturer>
                              <manufacturerURL>http://www.dbpoweramp.com</manufacturerURL>
                              <modelDescription>Media Server</modelDescription>
                              <modelName>Asset UPnP Server</modelName>
                              <modelURL>http://www.dbpoweramp.com</modelURL>
                              <modelNumber>1.0</modelNumber>
                              <serialNumber/>
                              <UDN>uuid:52882137-C26F-9872-0-123456789abc</UDN>
                              <presentationURL>http://10.0.1.10:45537</presentationURL>
                              <dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMS-1.50</dlna:X_DLNADOC>
                              <iconList>
                              <icon>
                              <mimetype>image/jpeg</mimetype>
                              <width>120</width>
                              <height>120</height>
                              <depth>24</depth>
                              <url>/images/platinum-120x120.jpg</url>
                              </icon>
                              <icon>
                              <width>48</width>
                              <height>48</height>
                              <depth>24</depth>
                              <url>/images/platinum-48x48.jpg</url>
                              </icon>
                              <icon>
                              <mimetype>image/png</mimetype>
                              <width>120</width>
                              <depth>24</depth>
                              <url>/images/platinum-120x120.png</url>
                              </icon>
                              <icon>
                              <width>48</width>
                              <height>48</height>
                              <depth>24</depth>
                              <url>/images/platinum-48x48.png</url>
                              </icon>
                              </iconList>
                              <serviceList>
                              <service>
                              <serviceType>
                              urn:microsoft.com:service:X_MS_MediaReceiverRegist rar:1
                              </serviceType>
                              <serviceId>
                              urn:microsoft.com:serviceId:X_MS_MediaReceiverRegi strar
                              </serviceId>
                              <SCPDURL>
                              /X_MS_MediaReceiverRegistrar/52882137-C26F-9872-0-123456789abc/scpd.xml
                              </SCPDURL>
                              <controlURL>
                              /X_MS_MediaReceiverRegistrar/52882137-C26F-9872-0-123456789abc/control.xml
                              </controlURL>
                              <eventSubURL>
                              /X_MS_MediaReceiverRegistrar/52882137-C26F-9872-0-123456789abc/event.xml
                              </eventSubURL>
                              </service>
                              <service>
                              <serviceType>urn:schemas-upnp-org:service:ContentDirectory:1</serviceType>
                              <serviceId>urn:upnp-org:serviceId:ContentDirectory</serviceId>
                              <SCPDURL>
                              /ContentDirectory/52882137-C26F-9872-0-123456789abc/scpd.xml
                              </SCPDURL>
                              <controlURL>
                              /ContentDirectory/52882137-C26F-9872-0-123456789abc/control.xml
                              </controlURL>
                              <eventSubURL>
                              /ContentDirectory/52882137-C26F-9872-0-123456789abc/event.xml
                              </eventSubURL>
                              </service>
                              <service>
                              <serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
                              <serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
                              <SCPDURL>
                              /ConnectionManager/52882137-C26F-9872-0-123456789abc/scpd.xml
                              </SCPDURL>
                              <controlURL>
                              /ConnectionManager/52882137-C26F-9872-0-123456789abc/control.xml
                              </controlURL>
                              <eventSubURL>
                              /ConnectionManager/52882137-C26F-9872-0-123456789abc/event.xml
                              </eventSubURL>
                              </service>
                              </serviceList>
                              </device>
                              </root>
