Asset R5 Discussions
  • alk630
    • Jun 2014
    • 89
    #31
    Re: Asset UPnP R5
    Well, my next question then is.... how, if I have an album with two discs, e.g. the 'Parov Stelar - The Princess' where the disc count has somehow been previously edited to 2, can I then edit it back to 1? Is there a program out there where the disc count can be directly edited? I know this may sound pedantic, but I would just like to control the appearance of the way albums are displayed in a large collection.
      • 5744
      #32
      Re: Asset UPnP R5
      dbpoweramp (from this site), select tracks, then right click, then EDIT ID TAG, modify disk tag info then save.
      mp3tag (which handles flac, etc. too)
      many other tag editors.....
      • alk630
        • Jun 2014
        • 89
        #33
        Re: Asset UPnP R5
        Thanks garym, that works... much appreciated
        Another problem with Asset UPnP for Spoon, apologies in advance for being a pain....
        I have a few albums and tracks by Émilie Simon, all spelled correctly. Some of them appear under [E], some appear under [0-9] and some appear in both [E] and [0-9] together. This appears to be the same using different control points.
        • alk630
          • Jun 2014
          • 89
          #34
          Re: Asset UPnP R5
          After getting to grips with the Disc Count settings this evening and re-encoding all the FLAC files in Adele 19 (Deluxe Edition) with XRecodeII, something very weird is going on, but it may be related to the previous problem Spoon is investigating. Now, all the files from the double album are correctly listed together, but there is a problem with one track (CD1, track 5) - see screenshot below:
          All the files in each album are tagged the same, but for some reason track 5 is displayed without the album number.
            • 5744
            #35
            Re: Asset UPnP R5
            [ATTACH=CONFIG]380[/ATTACH]
            open these files in mp3tag. select files, right click, choose "extended tags" to see what might be different regarding metadata tags. If you select all files from album and do this, you'll see if things are different in a tag (disk?) if it shows <keep> rather than the value for the album.
            • alk630
              • Jun 2014
              • 89
              #36
              Re: Asset UPnP R5
              Thanks garym, I already tried your suggestion, but there is absolutely no difference in the metadata tags. I think this problem is related to the one that Spoon is already looking at.
                • 43927
                #37
                Re: Asset UPnP R5
                Please try this new version here:
                The next generation of Asset. Changes New database design, faster at indexing, browsing albums Upstream art uses compilation artist, but will replace with non-compilation later Does not remove files from database when the whole location missing (such as nas share down) Compilation albums corrected to not show as Various
                After installing a full Rescan (Refresh All) should be done to re-index.
                • alk630
                  • Jun 2014
                  • 89
                  #38
                  Re: Asset UPnP R5
                  Should Asset be able to routinely pick up case changes in an Album or Artist, e.g. 'When the Wind Blows' -> 'When The Wind Blows' or 'Abba '-> 'ABBA' and update accordingly? This does not appear to be happening in some instances.
                  Edit: Only just seen your post for the new version of Beta 5, so will let you know....
                    • 4015
                    #39
                    Re: Asset UPnP R5
                    In Asset UPnP Configuration, select Refresh All and you should definitely see the case changes when it has finished scanning.
                    • alk630
                      • Jun 2014
                      • 89
                      #40
                      Re: Asset UPnP R5
                      Congratulations and thank you Spoon, the new Asset Beta 5 appears to be working correctly without albums being duplicated.
                      There is still a problem with 'Émilie Simon' (with an e-acute) albums appearing sometimes in [E], sometimes in [0-9] and sometimes in both. 'The xx' appears in <Artist / Album> [0-9], but this may be by design if 'xx' is interpreted as Roman numerals? Albums beginning with '&' and various other symbols e.g. '.' when not followed by a number are also appearing in <Albums> [0-19], along with various other albums beginning with regular alphabetical letters (see screenshot):
                        • 43927
                        #41
                        Re: Asset UPnP R5
                        Check if these albums have an Album Sort tag set.
                        • alk630
                          • Jun 2014
                          • 89
                          #42
                          Re: Asset UPnP R5
                          Last night, after adding a new Led Zeppelin album to the collection, in the control point the album doesn't appear under <Album / Artist>, but does appear under <All Tracks>. All the tagging appears to be correct. Any ideas as to what may be happening here please?
                            • 43927
                            #43
                            Re: Asset UPnP R5
                            It is missing in Asset Control?
                            • alk630
                              • Jun 2014
                              • 89
                              #44
                              Re: Asset UPnP R5
                              No, sorry I didn't check there.. it was missing in Kinsky - I hadn't realised different control points treated things differently and the album does show in Asset Control.
                              I posted last night (it seems to have disappeared) to say the new version is working very well, but there was still a problem with album artists starting with E-acute appearing in both [E] and [0-10] together. This happens in both Kinsky and Asset Control... is this normal behaviour?
                              Apologies for all the questions, there appears to be quite a steep learning curve to begin with, but I'm getting there
                                • 43927
                                #45
                                Re: Asset UPnP R5
                                The post is now above.
