Asset R5 Discussions
  • alk630
    • Jun 2014
    • 89
    Re: Asset UPnP R5
    My database was 138 Mb, so I had to upload it to file-sharing host ZippyShare. I sent a link to the e-mail address provided in your link.
    The problem with <Disc 1> missing from some multi-disc sets happens regardless of the Disc Count in the tags for some albums. Both of the examples I gave you are labelled exactly the same way with the Disc Count tags 01 for the first album and 02 for the second album. This inconsistency problem exists multiple times throughout my collection.
    With 'Adele > 19 (Deluxe Edition)' the second disc of the double album appears twice.... '19 (Deluxe Edition), Disc 2' with just '1. Chasing Pavements' track and again '19 (Deluxe Edition), Disc 2' with the remaining tracks 2-10. This problem also happens multiple times throughout my collection.
    • alk630
      • Jun 2014
      • 89
      Re: Asset UPnP R5
      Here are some screenshots from Asset Control:
        • 43928
        Re: Asset UPnP R5
        Yes I have your database, I thought you had uploaded a 2nd.
        Asset is reading those tags differently, if you have dBpoweramp installed, select all the tracks for the Coco disc 1 >> right click >> Edit ID Tags, it should say:
        Disc 1/2 (or 3, or 4)
        If one of the tracks has the wrong tag, it can cause issues.
        About the duplicate albums, yes I can see this now in the database, we need to think how this happened.
        • alk630
          • Jun 2014
          • 89
          Re: Asset UPnP R5
          I know Asset is reading the tags incorrectly or the problem would not occur, but both the examples I gave you are labelled the same way, i.e. Disc Count tags '01' for all tracks on the first album and '02' for all tracks on the second album. I have checked this in the latest versions of both Tag&Rename and Mp3Tag. Therefore, this appears to be inconsistent behaviour on the part of Asset UPnP.
          Thank you
            • 43928
            Re: Asset UPnP R5
            Your images (mp3tag) confirm the disc is missing the disc count it should be:
            1/2
            for disc number, if no disc count is specified asset does not know to put ', Disc 1'
            • alk630
              • Jun 2014
              • 89
              #21
              Re: Asset UPnP R5
              1/2
              If you look at the example screenshot I have provided from Asset Control in post *18, you will see that even though no disc count is provided for Parov Stelar - The Princess, the first album still shows ', Disc 1'. This is not the case with Parov Stelar - Coco and, therefore, the behaviour is inconsistent!
                • 43928
                #22
                Re: Asset UPnP R5
                'The Princess'
                According to the database dump does have a disc count. For example:
                Beautiful Morning The Princess, Disc 1 Track: 13/15 Disc: 01/2
                It is the /2 it goes off.
                • alk630
                  • Jun 2014
                  • 89
                  #23
                  Re: Asset UPnP R5
                  'The Princess'
                  Arggghhh!! Neither Tag&Raname or mp3tag show the disc count, so how is the user supposed to know this?? This is very frustrating, although I realise it may not be Asset UPnP at fault.
                    • 43928
                    #24
                    Re: Asset UPnP R5
                    Could you give some details please of your system Asset is running on? (processor, Windows version, 64 bit or 32 bit, memory, main system storage drive, is SSD?)
                    • alk630
                      • Jun 2014
                      • 89
                      #25
                      Re: Asset UPnP R5
                      Windows 7 x64 SP1, fully patched. Processor Intel Core i7 Ivy Bridge (i7-3840QM) socket 988B rPGA. 8Gb of RAM. The main drive in an Intel SSDMCEAC12 128 Mb SSD. I have 4 x 3 Tb Western Digital drives in RAID 10 for storing the music.
                        • 43928
                        #26
                        Re: Asset UPnP R5
                        If you could send us the actual database file, it is called
                        uMediaLibraryMainDBv5.bin
                        and is in:
                        %appdata%\dBpoweramp\uMediaLibrary
                        paste the above in Windows File Explorer to get to the real location.
                        If Asset is run as a service then it is:
                        C:\Windows\SysWOW64\config\systemprofile\AppData\R oaming\dBpoweramp\uMediaLibrary
                          • 4015
                          #27
                          Re: Asset UPnP R5
                          Are these files flac or mp3?
                          If they are flac, click customize columns... in MP3Tag and add a new column with Name = DiscTotal, Value = %disctotal% and Field = %disctotal%
                          Remember tagging mp3 and flac files differs due to the standards for ID3v2 and Vorbis Comments respectively.
                          • alk630
                            • Jun 2014
                            • 89
                            #28
                            Re: Asset UPnP R5
                            Details sent to your e-mail as requested.
                            • alk630
                              • Jun 2014
                              • 89
                              #29
                              Re: Asset UPnP R5
                              Hello mville... Thanks for the information about mp3Tag, all the files are FLAC. Do you know if there is a way to display this information in Tag&Rename too please?
                                • 4015
                                #30
                                Re: Asset UPnP R5
                                Sorry, no, I don't use Tag&Rename as MP3Tag supports all my tagging requirements.
