VisualBasic 2010 programm does not work with Scripting dBpoweramp Music Converter
  • phaegar
    • Jan 2014
    Hello!
    I want to develop a program to manage my audio library. Therefore I want to use Scripting dBpoweramp Music Converter.
    My current system:
    - Windows 7 Ultimate 64 bit
    - Visual Visual Studio Express Version 10.0.40219.1 SP1Rel with Visual Basic 2010
    - Microsoft .NET Framework Version 4.5.50938 SP1Rel
    - dBpoweramp 64bit: Registered Reference Release 15
    dMC-Scripting VBScripting.vbs works fine as well as test.vbs with following content:
    [COLOR=*808080]Dim intTemp, strCodec, dMC
    Set dMC = WScript.CreateObject("dMCScripting.Converter")
    Do
    strCodec = dMC.GetCompressions(intTemp)
    If Len(strCodec) > 0 Then
    msgbox strCodec, vbOKOnly + vbInformation, "dMCScripting.Test"
    intTemp = intTemp + 1
    End If
    Loop Until Len(strCodec) = 0[/COLOR]
    From regsvr32 "c:\program files (x86)\illustrate\dBpoweramp\dMCScripting.dll" I get a successful registered message. Nevertheless dmcscripting.dll does not appear as a COM reference in VB 2010 Express and adding it manually as reference into the project properties dows not change the result.
    I really have carefully researched into the Illustrate forum. There are some threads with similar problem definitions (e.g. http://forum.dbpoweramp.com/showthre...hlight=activex), but without a fitting answer or hint for a possible solution.
    Exceuting the VisualBasic program following error message occurs:
    ActiveX component can't create object: 'dmcScripting.Converter'
    The error message is caused by this code :
    [COLOR=*0000cd]Dim dMC
    dMC = CreateObject("dMCScripting.Converter")[/COLOR]
    I hope I will receive answer which I can understand and use. Many thanks in advance.
    • 43964
    Re: VisualBasic 2010 programm does not work with Scripting dBpoweramp Music Converter
    If .vbs scripting works, then it is correctly registered on the system otherwise vbs would not work.
    R15 is true 64 bit, yet you have the 32 bit version installed, why is this?
    • phaegar
      • Jan 2014
      Did I? I only could download one file after the purchase. How can I get the 64 bit version?
        • 43964
        You would have to uninstall the old version, then reinstall and it should install 64 bit version.
        • phaegar
          • Jan 2014
          Do I need another installation file or how can I ensure that the 64 bit version will be installed? because recently I uninstalled Version 14 and reinstalled version 15.
            • 43964
            See:
            The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. CD Writer CD Writer cannot be compiled to 64 bit, it is 32 bit only.
            for how it detects and installs the 32 bit version.
            • phaegar
              • Jan 2014
              After reading the hints at http://forum.dbpoweramp.com/showthre...-Compatibility I&*8217;m sure, that I have installed the 64 bit version. The software is installed to &*8220;C:\Program Files\dBpoweramp&*8221;. The file directory &*8220;c:\program files (x86)\illustrate\dBpoweramp\&*8220; does not exist (everything of the older version was deleted before I installed release 15). Afterwards it&*8217;s clear to me that this command was redundant (so this was my mistake).
              I scan the entire registry file to ensure that there were entries with this string "c:\program files (x86)\illustrate\dBpoweramp\dMCScripting.dll". Only one entry was found which I changed to &*8220;C:\Program Files\dBpoweramp\dMCScripting.dll".
              After rebooting the system and trying to execute my program again I still got the error message at the same position into the code: &*8220;ActiveX component can't create object: 'dmcScripting.Converter'&*8221;.
              So, what&*8217;s wrong?
                • 43964
                Why is dmc not dMC?
                • phaegar
                  • Jan 2014
                  Sorry, this I've copied the wrong error message.
                  The correct message is "ActiveX component cannot be created" and it occurs through
                  Any idea?
                    • 43964
                    Sorry I do not have any clues here. We have updated the c* example:
                    Try this please. This would show that it is working to an extent.
