Problem with utility codecs
  • keithbaran
    • Feb 2004
    • 37
    Hello all,
    I just switched from Win XP to Win 7 64 bit. I have updated Music converter to V15 and all codecs. I use to be able to right click on a music file, select " convert to" at which time I could, from a drop down menu, select several choices such as "wave", "mp3", "Flac" etc. including utility codecs such as " arrange audio", "tag from file name" etc. Since the switch to Win 7 64 bit no utility codecs appear in the drop down menu when I right click on a music file and choose " convert to".
    I have re-installed the current utility codecs several times with no luck. I apologize if this is answered somewhere in the forums, but I cannot find an answer. Any assistance would be appreciated
    Regards
    Keith Baran
    • 43980
    Re: Problem with utility codecs
    You must have 32 bit dBpoweramp still installed, see:
    The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. CD Writer CD Writer cannot be compiled to 64 bit, it is 32 bit only.
    • keithbaran
      • Feb 2004
      • 37
      Thank you Spoon, I did uninstall the old version first but just deleting that file did the trick. As always, you, this product, and company are the best, Rock On!!
      On a side note any updates on a release of the new dAP?
        • 43980
        We are going a totally different direction for dAP...
