Asset UPnP for QNAP
This topic is closed.
    • 43964
    #61
    Re: Asset UPnP for QNAP
    Yes slimserver.pl is nothing to do with asset.
    A QNAP is probably 100x slower than your PC, it might only have 512MB of memory and a ARM CPU.
    • katywu
      • Nov 2011
      • 26
      #62
      Indeed, it does have 512MB of memory and an ARM CPU
      Presumably some of the intel QNAP boxes would be comparable
      • kg648
        • May 2011
        • 52
        #63
        If you stop streaming what happens to cpu?
        it drops to 88% when not streaming and if I disable asset 4%
        If I can somehow provide further diagnostics or logs let me know.
          Super Moderator
          • 1366
          #64
          kg648,
          What audio formats do you have in your music library?
          It would be most useful if you could enable logging in Asset configuration, keep Asset running with high CPU usage for a minute and email us the logs [ http://www.dbpoweramp.com/email.htm ].
          • kg648
            • May 2011
            • 52
            #65
            Hi
            It appears you are right, it is when the library rescans - it has long completed the full rescan I assume it is just rechecking for new content but when this happens it occasionally drops a few times in a track.
            It does appear to be checking quite frequently though. - i'll e-mail the log anyway but obviously I guess it should not affect streaming a file to one device whilst doing a rescan? or is my qnap simply just not powerful enough for what I am expecting? it's only job is to stream music and run the array.
            Log should be in your inbox if that is any use.
              Super Moderator
              • 1366
              #66
              Thanks for the feedback. Even if the CPU usage occurs only during rescans, this situation is unacceptable and is being looked into.
                • 43964
                #67
                Looking at the log, there is 100's of requests for:
                That is the control point or player constantly requesting the same album art and requesting that Asset resizes the art to 90 pixels. What player and control point are you using, because it should not be doing this.
                • kg648
                  • May 2011
                  • 52
                  #68
                  A Linn Majik DS sir, just tried it on my renew DS and it seems to do the same thing.
                  • michel-rose
                    • Jan 2014
                    • 13
                    #69
                    Hi kg648,
                    This is not what i see on my mdsi.
                    I have default settings for cover art etc.
                    mdsi using latest firmware
                    • kg648
                      • May 2011
                      • 52
                      #70
                      Originally posted by michel-rose
                      Hi kg648,
                      Same here, not changed any cover settings and running the latest firmware :(
                        • 43964
                        #71
                        Which control point do you use?
                        • kg648
                          • May 2011
                          • 52
                          #72
                          I use Kinsky.
                            • 43964
                            #73
                            On PC or iPad? is it the latest version?
                            • kg648
                              • May 2011
                              • 52
                              #74
                              on a PC, yup latest version - sorry I should of been more specific.
                              • michel-rose
                                • Jan 2014
                                • 13
                                #75
                                Kinsky on pc, latest version
