dBpoweramp R15 BETA Discussions
  • ffm76600
    • Apr 2007
    • 162
    #46
    Re: dBpoweramp R15 BETA Discussions
    Shenook
    DMC 15 (64bits version) is not compatible with WMA
      • 43949
      #47
      A 64 bit version of WMA will be available shortly.
      • Shenook
        • Dec 2013
        Thank you, Thank you! Now I know I'm not just nuts. Guess I'll rip to FLAC and Re-rip when the 64 bit version is available then.
        • Porcus
          • Feb 2007
          • 792
          #49
          Convert, not re-rip. (Just in case you didn't mean precisely that.)
          • margolbe
            • Nov 2006
            • 15
            #50
            I installed the beta over my registered version. However, I just got a message saying there is only 3 days left in the trial (although the Beta says it functions until 4 2014.
            Does this mean that the beta will stop working in 3 days, or is there something else I must do to keep the Beta?
              • 43949
              #51
              It means it will revert to unregistered after 3 days, uninstalling and putting R14 back on will re-register.
              Because of the 32/64 bit difference in this build is is not easy to preserve the registered status through the beta. Full release however is only weeks away.
              • Shenook
                • Dec 2013
                Do you have an ETA on this now that we are in January?
                • ffm76600
                  • Apr 2007
                  • 162
                  #53
                  @Shenook :
                  You can download the new WMA codec here (beta version) :
                  These installs contain both 64 bit install (for dBpoweramp R15 beta 64 bit) and 32 bit installs. By default the install will match your dBpoweramp (32 bit or 64 bit). AAC Encoder Now Released: http://www.dbpoweramp.com/codec-central-m4a.htm CLI Encoder Now Released: http://www.dbpoweramp.com/codec-central-cli.htm m4a &
                  • branchh
                    • Jan 2014
                    • 10
                    #54
                    Just installed R15RC; started testing AIFF & MP3 ripping; I thought you had moved id3 2.4 in R15? Everything I see is still written as 2.3. All the dialogs in Config, Code, Advanced show v2.3. What's up? 2.4 was release in 2003. Beatport releases MP3 & AIFF files in 2.4 for a while. iTunes supports 2.4. most standalone taggers support 2.4. Traktor supports 2.4. Mixed in Key supports 2.4. Also need more options for how you are entering Rating tag (POPM) - I don't prefer to utilize WMP scale - can you make this a settable value for each rating? I would like to be able to enter Traktor's scale: traktor@native-instruments.de 0=POPM=0; 1=POPM=51; 2=POPM=102; 3=POPM=153; 4=POPM=204; 5=POPM=255
                    • branchh
                      • Jan 2014
                      • 10
                      #55
                      My mistake... I see MP3 2.4 tag option in Config settings... What tag version is written to AIFF? my feedback regarding having Rating config options like being able to set what values I want written for 0,1,2,3,4,5 vs. them being hard coded to WMP POPM settings would be highly valued. Not everyone uses WMP POPM rating values like Traktor and other ID3 editors.
                        • 43949
                        #56
                        AIFF is always 2.3, everything supports 2.3, only about 50% supports 2.4
                        • thexfile
                          • Jul 2010
                          • 177
                          #57
                          The new beta 11 64bit (1/18) also adds a extra folder to the programs list "dBpoweramp" when it should be "dBpoweramp Music Converter." I'm not sure about the 32bit install.
                          Also,
                            • 43949
                            #58
                            This folder has now been dropped, and replaced by dBpoweramp, only by uninstalling the previous beta would it clear that folder, otherwise you would get 2.
                            The create desktop icons have been added because Windows 8 is such a mess when it comes to finding programs, never once in 14 years did we feel the need to put icons on the desktop until Windows 8 comes along.
                            I will see if it can be more informative.
                            • thexfile
                              • Jul 2010
                              • 177
                              #59
                              I've done a uninstall and reboot.
                              Noticed the installer says beta 10 the configuration window says beta 11 and in programs and features it says beta 10.
                                • 43949
                                #60
                                Just a typo on the installer
