Problems getting Nimbie to work
  • ddetaey
    • Jul 2010
    • 16
    I am trying to use the Nimbie for secure batch ripping, but encounter the following problem:
    After the Nimbie has loaded a CD, each time I get the following error message : "No CD after load"
    Any idea what I am doing wrong?
    Thanks for your support
    Dirk
    P.S. the Nimbie works fine with another ripping program
    • 44017
    Re: Problems getting Nimbie to work
    Which Windows Version?
    • ddetaey
      • Jul 2010
      • 16
      Windows 7 64-bit Professional
      Dirk
        • 44017
        If you have multiple CD drives, make sure you have configured the correct drive letter as the Nimbie
        • ddetaey
          • Jul 2010
          • 16
          As the Nimbie correctly loads and unloads the CD's, and in CD Ripper the right drive letter is selcted, is there any other place where this needs to be configured?
          Dirk
            • 44017
            No, sometimes the drive letters can be swapped especially if manually assigned a drive letter.
            No CD after load suggests that dBpoweramp cannot communicate with the CD drive. Load a disc in the drive and try CD ripper to see if recognizes the disc (without using the robot).
            • ddetaey
              • Jul 2010
              • 16
              Hi Spoon
              Loading the disc manually did the trick. It enabled me to setup AccurateRip correctly and it ripped the disc as usual.
              Retrying using the robot after that worked immediately. I still don't understand why, but hopefully it keeps on working now
              Maybe one last question, are there any issues enabling Ultra Secure Rip using a robot (the Nimbie in particular), or is it better to remain with AccurateRip ?
              Dirk
                • 44017
                Ultra secure does use AccurateRip, for most people just using AccurateRip is enough.
                • wpchase
                  • Sep 2014
                  • 10
                  I have this issue as well. It occurs when I begin another batch after the first has completed. First the "Unable to locate Nimbie, is connected?" error pops up. Then it will actually load a disc and reject it.
                  dBpoweramp Batch Ripper
                  Batch Name:
                  Batch ID: 50025
                  Using Profile: npr_program
                  Batch Rip Started: 9/30/2014 16:45:07
                  : Reject 1: No CD After Load Reject 1: No CD After Load
                  : Reject 2: No CD After Load Reject 2: No CD After Load
                  However, once it resyncs(?) with the drives, the batch will run.
