One PC (quadcore) with 6 CD player, OK for batch ripper ?
  • erpch
    • Jan 2011
    Hello,
    Does batch ripper work with one PC (quadcore, 2 Go RAM and 6 CD Player SATA) ?
    Eric
    • 43930
    Re: One PC (quadcore) with 6 CD player, OK for batch ripper ?
    Should be ok, I would not go above 6 CD drives on a single system, rather use a 2nd system if you need more CD drives.
    • erpch
      • Jan 2011
      Thank you for your answer. I will try with 3 drives before to add 3 more.
      Could you estimate the speed of the CD conversion to FLAC (include accurate RIP) for these configuration : 6 drives, intel quadcore 6600 2,4 Ghz, 2 Go RAM ?
      The CD are in good conditions.
      Eric
        • 43930
        Around 20x speed for each drive, dependant on drive. So around x120 speed for 6 drives, or one disc every 30 seconds.
        You might want to bump the ram to 4GB
        • erpch
          • Jan 2011
          Thanks, I have to buy 5 CD Drives, can you recommend a model ?
            • 43930
            Wait 24 hours and take a look at the new CD Drive Accuracy List 2011 which is going to be posted.
            • erpch
              • Jan 2011
              Did you post the list ? I don't know how to find it...
                • 43930
                CD/DVD Drive Accuracy List 2011 AccurateRip collects data from all drives, normally this is only used to verify a disc is accurate, but can be reversed to calculate which drives are the most accurate (as measured by lowest % inaccurate tracks). This test was previously run in 2009 and 2006, as time goes on more
                • erpch
                  • Jan 2011
                  Thank you very much !!!
                  • soongsc
                    • Jan 2011
                    • 96
                    I have a 8 core machine with 4GB ram, never was able to see throughput like that. Normally each disk takes at least 10 minutes. Is this due to up sampling? rarely been able to see real rip speeds above 13x even though the drives are much faster.
                      • 43930
                      You should not be changing the frequency or bitrate, noting to be gained...
                      It is drive specific, I have tested drives which will reliably rip at x40 when it reaches the edge of the disc (starts out at about x16)
                      • Z0001
                        • Mar 2011
                        • 55
                        I too am interested in setting up an optical drive tower with the idea of speeding up the ripping process. If I was to set up 4 drives would dbpoweeramp rip simultaneously or sequentially? Would this strategy be quicker than a single drive? I have an i3 530 and 4GB RAM and will be ripping to a QNAP TS 419P+ NAS across a gb network.
                        Cheers
                          • 43930
                          Batch Ripper would rip simultaneously. It would be 4x faster than a single drive (if using 4 drives).
                          • Z0001
                            • Mar 2011
                            • 55
                            Tremendous! Thanks Spoon.
                            • CaryB
                              • Feb 2009
                              • 22
                              For those of you toying with this idea, I have an AMD quad core cpu, 8gigs of ram, and 6 ESATA CD/DVD drives, all in one tower. I use various brands of drives, so if one hangs, I can try a different one. (and I was cheap, picked up whichever was cheapest at the time.)
                              I get around 100 to 120 accumulated ripping times on average. Works great. I stack up about 20 or 30 cds, then just start feeding them in. Once it gets going, if the CD's have no errors, I am constantly changing discs. (I do have it set to let me review MetaData if it finds no album covers, etc. So that slows it down a bit on some albums.)
                              I am also ripping all these to a Server running Unraid. Gigabyte ethernet. No bottlenecks at all. (If I had only 100mb network, I would rip them to the hardrive, then transfer when finished.) My biggest batch yet was about 60 CD's. Took around a half hour or so if I remember correctly.
