Asset Control Discussions
  • Magnus Thomé
    • Nov 2011
    • 25
    Re: Asset Control Discussions
    Odd thing is that other control points like Linn's Kinsky (on pc) and many control points on Android displays albums as thumbs even with JRiver an Squeezeserver. Is there any possibility to override and display everything as thumbs instead of lists?
      • 43930
      This is because Kinksy shows everything in a list like that (if I remember correctly). Asset Control tries to be smarter.
      • Magnus Thomé
        • Nov 2011
        • 25
        If you ever get around fiddling with the Asset code (I know it's on the back burner) could you possibly add a settings option to force it to be dumber and show thumbs :komisch12 Just wishing :D
        Cheers!
        • Michael Sargent
          • Dec 2009
          • 134
          Re: Asset Control Discussions - Disc/Track order
          Originally posted by Chip
          Does Asset Control recognize Disc number in multi disc albums?
          I have many multi disc albums and I see all track 1s listed together instead of in disc order.
          What do I need to do to get the disc/track order correct?
          Originally posted by mrspoonsi
          It is the upnp server which does this, not control point.
          What are the correct options for Asset UPnP to make it sort tracks within multi-disc albums properly? I do have the Disc Number and Number of Discs metadata set correctly in all cases (i.e., Disc 2/4 shows up in the properties). I played with a couple of settings (one required the whole library to be rescanned) and I still haven't found the right incantation.
          Mike
            • 43930
            Multi Discs are going to split to appear as separate albums.
            • Michael Sargent
              • Dec 2009
              • 134
              That's not what I'm seeing. For a 4 disc album, I see 4 track 1's followed by 4 track 2's, etc.
                • 43930
                If you have dBpoweramp installed, right click on a track >> Edit ID Tag
                it should show:
                disc 1/4
                etc, does it?
                • Michael Sargent
                  • Dec 2009
                  • 134
                  That's what I see. For instance:
                  Disc 2/4
                  In foobar2k track >> Properties I see:
                  Disc Number 2
                  Total Discs 4
                  Anything else I can try?
                  Mike
                    • 43930
                    In Asset >> Advanced you have: Multi-Disc Albums Show as 'Album, Disc x'
                    • user2112
                      • Jul 2009
                      • 57
                      Hi Spoon, Control is running slow and not loading album art correctly. Have reinstalled control and also restarted asset server. Kinsky works fine.
                      the problem coincided with a win7 update but not sure if that is significant.
                      Any Ideas?
                      Cheers
                        • 43930
                        Sorry no.
                        • Michael Sargent
                          • Dec 2009
                          • 134
                          Yes, I have that checked on. Is that what I want, because it doesn't seem to help?
                            • 43930
                            yes it should split multi discs.
                            • Michael Sargent
                              • Dec 2009
                              • 134
                              It doesn't seem to be working. I did a complete rescan and restarted Asset UPnP. I am using the latest Asset UPnP (downloaded a week or two ago).
                              The version of Asset Control I have is dated 15-Sep-10 08:19 and has the file version number 1.0.0.1 (latest?).
                              • Michael Sargent
                                • Dec 2009
                                • 134
                                Any thoughts on this Spoon? I think I have the latest versions of everything, I think the options are set right, I have done rescans and rebooted everything several times, and it's still not working. And it's not just Asset Control that still showing several track 1's together, etc. so I suspect that the option in Asset UPnP isn't working.
                                Mike
