SPOON PLease Help!
    SPOON PLease Help!
    db codec's retarted
    Read This:
    Requires codec.exe to be installed - follow these instructions:
    Visit MPEGsuite and download Mpeg Suite 2000 and install,
    Create a large Wave file (best way is to Rip an Audio track using dMC),
    Run Mpeg Suite 2000 - in Encode (wav 2 Mp3) select your Wave file and click >>, then Encode,
    Whilst it is encoding have a look in C:\Program Files\Electronic Cosmo\MPEG Suite\ and copy codec.exe to C:\,
    That is it, you can now encode using this excellent codec.
    Is a CLI Encoder - requires Power Pack, see notes in Codec Central.
    Ok simple enough right? But when you go to the folder to find codec.exe, theres no such thing WTF!!!!!! Anyone know how to solve this mystery?
    Spoon's Reply,
    It is only there whilst it is encoding, try encoding a big file.
    When I try to encode a wav file I get this message:
    "Unable to run encoder 'C:\codec.exe"
    This means The Program Can Not Find This EXE, Is it included with the Program?, So Once again I ask Where Do I find This CODEC.EXE, It DOES NOT appear while its enoding, cause I CANT ENCODE ANYTHING!!....BTW I've already reinstalled db poweramp twice
    • 43930
    I meant try encoding a big file with Their studio, when you are trying to grab out the codec.exe - it is only there whilst you are compressing a file with mpg studio.
