Issue with embeding art
  • exsava76
    • Apr 2024
    I'm on a trial now, and already love the CD ripper. The only issue I consistently have after having ripped about 40 CDs is that each time I need to change an art, and/or number of disk in a set (like 3/10) the ripper accepts the changes to metadata, but saves initial values/art that were there before I've manually cnaged them.
    its either a bug, or I'm doing something very wrong, like not hitting some "SAVE" button or something...
    • 43994
    Re: Issue with embeding art
    You cannot change once Rip is clicked.
    • exsava76
      • Apr 2024
      I change before starting ripping
        • 1750
        Did you add an additional album art or delete and replace the offered album art? Most players will show you only the firstvembedded album art.
        • exsava76
          • Apr 2024
          What I do is:
          1 - insert CD
          2 Ripper find metadata online
          3 I drag and drop an alternative art into the right lower window + change disk numeration
          4 press RIP
            • 1750
            Try to delete the offered album art first, so that there is no album art to be seen in the preview and then drag & drop. Does it help?
            • exsava76
              • Apr 2024
              Thank you. It solved the issue
