Ripping to DSD and loud clicks when tracks selected for playing.
  • Howie407
    • Dec 2023
    I have DSD tracks that have been converted from a CD. When I play them through software and USB to my DAC there is loud click when first track plays or when I manually select a track from a list. There is no click apart from the first if the software plays through tracks automatically. Some software clicks others do not.
    Any idea, I am concerned about my speakers.
    Howie
    • 43930
    Re: Ripping to DSD and loud clicks when tracks selected for playing.
    What did you convert to?
    • Howie407
      • Dec 2023
      DSD 512 and then again DSD 256.
      Both the Matrix S and my SMSL SU-10 Dac are capable of handling both natively. Local drive attached to the Element S which connects to the DAC with I2S.
      I don't think that the problem is necessarily a hardware problem with the Element S, however there is a setting in the Element S "Gapless" with a warning that the setting in DSD might mean that there is no autoplay of successive tracks. I found that to be the case.
      Howard
