Key Disc Problem with AccurateRip
  • BrianJB
    • Nov 2023
    I've been using dbpoweramp for years, but just got a new PC and upgraded to a new version and installed the new software. I'm unable to get accuraterip to work. If I recall, this used to be an easy process with just putting in a few discs and I was ready to go. I've tried a few dozen discs and they either "don't match the database" which is hard to believe since I already ripped them previously, they came up as accurate and the details were sent at the end of the month (a year or so back).
    Anyway, this is what I am currently getting:
    What can I do to make it work?
    Thanks!
    Brian
    • 5744
    Re: Key Disc Problem with AccurateRip
    just keep feeding CDs, some folks have had to feed 30 or more CDs before AR configures. I suspect it has to do with the offset of the drive you are using.
    • BrianJB
      • Nov 2023
      Did you look at the image I posted? Every disc I find just says that the miss-mattches the drive database offset. Calculated is +16 samples, +64 bits. It won't work.
        • 5744
        Yes, that's why I said I suspect the problem has to do with the drive offset. But I'm out of ideas (I'm just another user like you). @spoon will need to chime in.
          • 1748
          Is C2 error pointer turned off or on?
            • 43928
            1400 people have all had the same offset of +6 for this drive. Unless there is a new issue of the drive with a different firmware which changes the offset, I tend to believe it is +6.
            • BrianJB
              • Nov 2023
              So is there a way to manually set it to 6 or do I just need to replace the drive?
              B.
              • BrianJB
                • Nov 2023
                It is unchecked.
                B.
                  • 43928
                  Get a different drive, totally different model.
                  • BrianJB
                    • Nov 2023
                    Can you link me a drive that you think is good?
                    B.
                      • 43928
                      Any should do, stay away from Sony optiarcs.
                      • BrianJB
                        • Nov 2023
                        I found two old drives at work--one wouldn't read a disc, but the other worked fine and the first disc I put in registered aa a key disc, so back in business. Thanks,
                        Brian
                          • 5744
                          Brian
                          excellent!
