Settings when ripping to 16 or24bit FLAC in dbPOWERAMP CD RIPPER
  • AforAndromeda
    • Jul 2023
    I would like to clarify the settings for ripping my CD to Flac. I can't seem to get it correct.
    Unlike the settings in Multi Encoder for WAV, (with both bit depth and sample rate), the FLAC setting seems just to consist of a choice of lossless encoding level.
    I wanted to produce a couple of tests creating a 48k bitrate and a 96khz FLAC versions (p.s. I know it's pointless with a 44.1khz + 16bit source,) but I would like to do it.
    Can you please clarify where I change the settings?
  • AforAndromeda
    • Jul 2023
    Re: Settings when ripping to 16 or24bit FLAC in dbPOWERAMP CD RIPPER
    Originally posted by simbun
    If you're looking to increase file size then you can use the 'Bit Depth' and 'Resample' DSP Effects.
    Obviously you won't have a bit perfect copy of your CD at that point, in case it matters.
    Thank you Simbun. Appreciate the quick response.
    A.
