dBpoweramp Reference won't convert .wma to.flac
  • IslandBoy
    • May 2023
    I've had dBpoweramp (paid-for) since R14 in 2013. I had used it many times in the past to convert .wma to .flac.
    I discovered today that I'd missed a few files so turned to dBpoweramp (now at R16.6 64-bit), did the convert-to right click and I get the following error message:
    Error converting to FLAC, 'C:\Users\FYL\OneDrive\Music\Spoken Word\ISIHAC\ISIHAC Humph in Wonderland\02 Humph Down the Rabbit Hole.wma' to 'C:\Users\FYL\OneDrive\Music\Spoken Word\ISIHAC\ISIHAC Humph in Wonderland\02 Humph Down the Rabbit Hole.flac'
    Error: Unable to load decoder for file type '.wma', codec not installed? visit 'Codec Central'. [dBCoreConverter::dBCoreConverter]
    In Codec Central, it says that "Windows Media Audio (WMA) Microsoft V10 Pro, standard, lossless & voice. Windows Only [.wma, .asf, .wmv]" is "Included with dBpoweramp Reference"
    In the Audio Codecs List / Options of dBpoweramp itself, it does NOT list WMA Decoder under Decoder Options or Installed Decoders.
    How can I get dBpoweramp to install the wma codec so I can convert my wma to flac as I used to?
  • Wayne
    • Aug 2002
    • 1254
    Re: dBpoweramp Reference won't convert .wma to.flac
    Which OS are you running?
    • IslandBoy
      • May 2023
      Windows. Specifically Windows 11 Pro. Windows 11 Version 22H2 (OS Build 22621.1778)
      On a Dell Latitude. 11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz 1.80 GHz. 32 GB RAM. 64-bit
        • 45168
        WMA was standard in R17 or newer.
        • IslandBoy
          • May 2023
          It must have been possible before as all my CD rips were in .wma and I converted them into .flac. Was the wma codec previously available and now it isn't except in R17?
            • 45168
            It previously would have been an install on its own, we do not have that now.
