Need help to rename in batch converstion?
  • DLD-UK
    • Nov 2009
    • 20
    I'm trying to rename tracks in batch conversion and nothing I try works.
    Firsly I cannot manage to make the year just YYYY instead of including month and day too. I've read the webpage on the commands to use but I can't get anything to work. I tried GRAB but just got the word GRAB in the filenames.
    The other thing I want to do is replace blanks with _ and replace any characters that Linux doesn't like.
    My music is on a Windows machine but I want to copy it to a Raspberry Pi. On the Pi I will use LMS and Asset.
    Each time I tried to copy files to the Pi the copy command got upset with an & and tried to treat the rest of the filename as a command. This is almost certainly due to my ignorance and incompetence in copying as I have no idea of the best way of doing it.
    I think I should have sorted out these issues when I did the initial ripping but I failed to do that, mainly as I had no idea I needed to.
    Any help much appreciated.
    DLD
    • 43991
    Re: Need help to rename in batch converstion?
    It is likely you need to change the ID tags, not filename, which naming does.
    • DLD-UK
      • Nov 2009
      • 20
      Hi Spoon,
      Sorry I don't understand your reply. If I change the ID tags then I get that the new filenames would be what I want. But how do I do that for all of my flac files.
      There are various things I got wrong when I ripped the CD's but I didn't know that at the time. I also didn't work out a file naming system properly.
      I hoped I could fix these things with Batch Converter. Can I?
      • DLD-UK
        • Nov 2009
        • 20
        Originally posted by simbun
        [GRAB]1,4,[YEAR][]
        Your windows filenames will be fine on Linux, how are you transferring them?
        Thank you. I nearly got it right. I just missed off the last []
        I don't remember how I did the copy now. I just know that when it came across the & in the filename it treated the rest of the filename as a command.
        How do you recommend doing the copy?
