PerfectTunes 3.1 Not saving updates to ID Tags
  • AdyB
    • Dec 2021
    I have PerfectTunes 3.1 (fully registered) and recently when I update ID Tags, the changes are not being saved. I have an M1 MacBook Pro now running MacOS 13.2 (but I was having this problem before the most recent update).
    When I save the changes, the page in PerfectTunes seems to update:
Name:	Screenshot 21-1-23 at 22.25.jpg
    But when I go back in a couple of days later, the updates to Album/Artist & Artwork have disappeared:
Name:	Screenshot 25-1-23 at 20.13.jpg
    My music library is held on a Synology 218+ NAS running Asset UPnP v 7.5.
    • 43929
    Re: PerfectTunes 3.1 Not saving updates to ID Tags
    Change the tags, then close perfecttunes. Then browse by filename and folder, have the changes stuck?
    • AdyB
      • Dec 2021
      No.
        • 43929
        Then PerfectTUNES does not have access rights to the files (write).
        Copy one file to the local computer and try the test again, do the changes stick.
        • AdyB
          • Dec 2021
          Hi, yes - copying to my local drive and updating the tags from there has worked.
          A bit of a long shot but do you have any pointers as to how to how I can reinstate the write access rights to my NAS?
            • 43929
            Specific to the NAS, would be an option within the NAS which accounts have read or write access to a share.
            • No Nickname
              • May 2018
              • 28
              I am having the same issue. It seems like a new thing. My files are stored on a separate drive and I am accessing via Asset UPnP R7.6 bet 2 and perfect tunes 023-04-02 (1). I haven't changed permissions or updated my OS. Registered user Mac OS 12.6.3 with an M1 chip
              • No Nickname
                • May 2018
                • 28
                Actually I solved it. For some reason my version, which I have had for years, showed up as no longer registered. So I just bought it again and that has solved being able save tags
