Ripping Problems
  • TRK
    • Sep 2022
    Ripping Problems
    Hallo,
    I want to rip the CD "Al Hirt Al Time Greatest Hits". dbpoweramp first shows all titels are inacurate. So I want to rerip the CD again. dbpoweramp now said error for all titels. I can run the CD and listen to the music, but I can't rip it. I tried an other CD and all works fine. What shall I do?
    Greatings
    TRK
    • 1853
    Re: Ripping Problems
    Is your CD copy protected? Any hints on the CD cover?
    • TRK
      • Sep 2022
      Hallo Dat Ei,
      i can't find any hints that the CD is copy protected. But I think she is. Other ripping programms shows the same result.
      TRK
        • 1853
        You have written, that you can run and listen to the CD. On a PC or on a HiFi CD player?
