32-bit integer FLAC conversion not working
  • Lynx_TWO
    • Aug 2009
    • 81
    FLAC supports 32-bit integer (not floating point though) however, when I try to convert a 32-bit integer WAV file to FLAC, I get an error message saying the bit depth is too high.
    Thank you for your time!
    • 43985
    Re: 32-bit integer FLAC conversion not working
    The flac format supports 32 bits, the reference libries (libFLAC) do not:
    "FLAC supports 4-32 bps but the reference encoder currently supports only up to 24 bps."
    • Lynx_TWO
      • Aug 2009
      • 81
      Ahhhh got you. Thanks for the explanation!
