Right click integration
  • farata
    • Dec 2021
    Somehow I've lost converter right-click integration. I've tried integrating it from the app as well, but it doesn't work. How to get it back?
    farata
    • 43928
    Re: Right click integration
    Uninstall dBpoweramp, full restart of Windows then reinstall, if you have Windows 11 then the right click menu items are shown on a sub menu now.
    • Demodave
      • Jul 2003
      • 23
      Hey Spoon.
      Are there any thoughts to updating dBpoweramp so that the primary right-click menu in Windows 11 will feature dBpoweramp's convert? I see that other software like Dropbox has already updated for W11.
        • 43928
        Programs are limited to just one entry on the main menu, we have to rethink the menu system as we potentially have 4 which we add, and more than one and they go on 2nd menu like it is now anyhow
        • Demodave
          • Jul 2003
          • 23
          Good to know! Thanks for the update!
          • ForSerious
            • Aug 2017
            • 82
            Personally, I just used one of the ways that can be found online to revert the right click menu in Windows 11 back to its old glory. Though it would be nice if dBpoweramp came up with a solution, I think it's a blunder for Windows to have even made the UI change in the first place.
