Tags
  • Buzzer
    • Feb 2019
    • 30
    Tags
    Now that I have finally figured out how to rip box sets cds and end up with one CD icon in the server software (instead of 4 or 6 separate icon/covers from a box set) I would like to change previous rips of box sets that appear as separate CDs. For example I have 4 covers shown for Fleetwood Mac 25 Years set in album listing on server. Need help with tags to consolidate these multiple covers into one album in list of albums. Been trying in IDTags, but as I am an old guy, this stuff is very difficult without a video tutorial or detailed instructions. Thanks.
    • 5749
    Re: Tags
    1. Change the ALBUM tag field to the exact same album name for all disks
    2. Give each disk a unique disk number tag field value (disks 1, 2, 3, 4, etc.)
    3. If you want same artwork, copy the folder.jpg (or cover.jpg) you prefer into each disk subfolder. (or if you use a naming scheme that puts all the tracks in a single folder, with 1.01, 1.02....2.01, 2.02, simply make sure that single folder has the artwork you want as folder.jpg or cover.jpg.
    • Buzzer
      • Feb 2019
      • 30
      Re: Tags
      OK I have followed the directions on tag editing. Highlighted folders of the same box set, then right click on a selected file(s), choose Services >> Edit Tags with dBpoweramp. Then I type in Album name click OK at bottom and nothing happens. As I mentioned---- I need detailed instructions ----I am very novice at working with software. Not a genius like some of these software companies/developers expects everyone to be.
        • 43951
        Re: Tags
        After you change the album name, re do the right click Edit Tags, does it show the changed album name or the original?
        • Buzzer
          • Feb 2019
          • 30
          Re: Tags
          I have a folder named Fleetwood Mac 25 years on my server. When I open the folder there are 4 discs listed as follows The Chain; 25 Years, Disc 1, etc. I highlight the 4 folders to edit and go to services and edit tags with dbpoweramp. type in Fleetwood Mac in artist and 25 Years The Chain in album and then hit OK. Nothing changes after that. Still get 4 separate album covers on iPad server software under albums listing.
          • Buzzer
            • Feb 2019
            • 30
            Re: Tags
            If i redo the right click edit tags it shows the same name.
              • 43951
              Re: Tags
              Check that you have write access to the files, if they are stored on a network share bring them to the local computer. Any other programs which might be using the files close that program.
              What format is your audio saved in?
              • Buzzer
                • Feb 2019
                • 30
                Re: Tags
                If i need to change art work, I change it on my mac---I delete the artwork work folder and either drag or copy new art work to the song/albuum listing. My audio is saved in ALAC.
                • Buzzer
                  • Feb 2019
                  • 30
                  Re: Tags
                  PS I am working off the hard drive of Aurender server.
                    • 43951
                    Re: Tags
                    Move the files to the local computer, edit the tags, check they are edited then move them back.
                    • Buzzer
                      • Feb 2019
                      • 30
                      Re: Tags
                      OK I moved the files to desktop on computer. Highlighted, Edit tags with DBPoweramp. typed in album name. Clicked OK. Nothing happens. I'm not sure I am filling out all the lines of the window correctly. Very frustrating.
                        • 43951
                        Re: Tags
                        What audio type are your files?
                          • 5749
                          Re: Tags
                          When you say nothing happens, do you mean that the tag info doesn&*8217;t change (checking from your player, etc) or do you mean the file name does not change rather than the tag info.
                          • Buzzer
                            • Feb 2019
                            • 30
                            Re: Tags
                            Alac
                            • Buzzer
                              • Feb 2019
                              • 30
                              Re: Tags
                              OK I opened the HD of the Aurender. Opened folder of Artist box set. Highlighted the 4 separate cd from box set. Moved to desktop. Highlighted all folders in desktop. right click. Edit tags with DBpoweramp. typed in album name. typed in discs 1, 2 3, 4. Hit ok. Moved the 4 folders back to Aurender HD. They still appear on the list of albums was 4 separate CDs with same cover. I want them to appear as 1 cover. Like I mentioned-----
                              I need line by line specific instructions to make this work on my end.
