Manual Search not working
  • kmkkorn420
    • Oct 2021
    Hello
    i have never ran into an issue when using the manual search to pull in data from discogs. last night it would not work so i updated to current release and it is still saying no data found even though the release info is on discogs. not sure if its just these few cds not working or if a have an issue. its occurred on two different releases so far
    • 45158
    Re: Manual Search not working
    You could try an older release which worked in the past. Post the discogs disc url here for the one which is not working please.
    • kmkkorn420
      • Oct 2021
      in running 17.4 64 bit on win 10 pc
      the below are the 3 albums i tried today that are not working
      https://www.discogs.com/release/1981...ns-Of-An-Angel
      https://www.discogs.com/release/1859...ok-Of-Thanatos
      https://www.discogs.com/release/1059...reat-Stairwell
      • kmkkorn420
        • Oct 2021
        17.4 64 bit on win 10 pc. below are 3 albums that would not pull data in on the manual search
          • 45158
          Copy the URL without the bit on the end, such as:
          https://www.discogs.com/release/18590104
          • superofm
            • Oct 2021
            Thanks Spoon, your suggestion works, but until a few days ago there was no need to copy just a part of the URL. Why has the behavior changed?
              • 45158
              Discogs has changed their URL
              • Michael.K
                • Jul 2020
                I had the same problem with
                https://www.discogs.com/de/release/1...r-Battlefields
                After I have cut the URL to https://www.discogs.com/de/release/18638860 it worked. So thanks for the hint.
                Nevertheless I think it would be very helpful if you add a new Textfield "Discogs ID" to the manual search box. I think this ID is unique and I am sure that many users do not know this workaround.
                So I would be gratefull if you could add.
                • know2go
                  • Apr 2022
                  I'm trying to manually search this link
                  https://www.discogs.com/release/1599...t-Hits-1954-61
                  its active and I can see this record in Discogs.
                  However, when I paste it in the dbpoweramp, nothing happens.
                  Any configuration or other considerations I'm missing?
                  Thanks...
                  • know2go
                    • Apr 2022
                    This link doesn't work, too
                    Thanks...
                    Originally posted by kmkkorn420
                    Hello
                    • know2go
                      • Apr 2022
                      Hi, I just joined the forum, but my reply doesn't show somehow.
                      Anyways, I am interested in the resolution, this link is not working for me
                      Using Mac Catalina; dbpoweramp v17.5
                      Thanks...
                        • 45158
                        You need R17.7 this bug was fixed.
                        • know2go
                          • Apr 2022
                          Thank you Spoon.
                          After the upgrade, its working now.
                          • Doug Mackie
                            • Feb 2022
                            • 11
                            I'm not so sure, Spoon.
                            I'm using R17.7 on Windows 7 32-bit. The URL copy technique worked once for me last week, but not this week. Have tried copying the URL with and without the trailing text. Is there some special trick to making this work?
                            Discogs is the only accurate and reliable source for my CD content. FreeDB is hopelessly inaccurate and the other two sources rarely have my CDs. So without Discogs, my ripping is on hold.
                            Since the URLs can change at any time, perhaps it would be a good idea to keep the relevant code in a config file that could be available for users to download and install as needed. That way we won't have to wait for the next dBpoweramp release.
                            I'm a new user and otherwise the ripper is working great for me. Hope a solution can be found soon.
                            UPDATE: Never mind, I figured it out. The copy URL trick only works when the Manual Tag Edit window is already open.
