Problem with duplicate files.
  • John W
    • Jun 2021
    • 16
    I have many music files in wma that I want to convert to mp3. They convert ok, but then instead of one selection in mp3, I have two; one mp3 and one wma.
    Obviously I want to get rid of all the wma. What am I doing wrong? Thanks for any assistance.
  • GBrown
    • Oct 2009
    • 379
    Re: Problem with duplicate files.
    The converter adds the new format version. If you want to then remove the original file you can delete them in the file explorer. Note that converting from one lossy format (wma) to another (mp3) will result in additional sound quality drop.
    • John W
      • Jun 2021
      • 16
      Is there any setting I can use to make it automatically delete the wma file?
        • 45160
        Include the DSP effect 'Delete Source file'
        • John W
          • Jun 2021
          • 16
          Got it! Thanks much for your help.
            Some advice, backup your wma files before proceeding!
            • John W
              • Jun 2021
              • 16
              Good advice, esoecially for a novice like me. However been there, done that. Everything came out great. Thanks for all your help guys.
