Problem whith encoding
  • HONAKER
    • Apr 2021
    Hello, after serveral weeks of perfect function,my dBpoweramp refuse to encoding any file i propose to him. Start is blocked on 0% and nothing can restart it. I already uninstalled the program, and restart. Nothing. Damned! 500 files (all legals) are waiting for. Thank you for help.
    • 45164
    Re: Problem whith encoding
    Check your output location exists, browse to it using Windows File Explorer or Finder on the mac.
    If it does, try converting those files to the encoder set to 'Test Conversion', does that work?
